Hotpoint JE740WY/GY Microwave Oven Logo
Posted on Mar 26, 2011
I'm redecorating my kitchen and want to replace a very old Hotpoint CounterSaver R VM 58003 over the range microwave. Is there a new microwave on the market with the same dimensions? I am specifically looking for a microwave that is 14 in. deep. Everything I have seen is 15 in. or more. Thanks!
4 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 08, 2008
SOURCE: I have a hotpoint over
You can download GE owner's manuals and installation instructions here.
Otherwise, GE Customer Service is here and they can point you to the proper manual.
Anonymous
  • 11896 Answers
  • Posted on Jun 06, 2009
SOURCE: hotpoint Over the Range Microwave is LOUD
It is very likely that the motor that spins the plate is wearing out. You can find a replacement on ebay and many other sites.
John Riley
  • 441 Answers
  • Posted on Jan 07, 2011
SOURCE: How do I remove my Hotpoint countersaver plus
In the cabinet above the unit you will find 3 screws, 2 on the right side one on the left. As soon as these are removed the micro will free to fall, you need to lift the back of the micro up about 1/2" to lift it off the mounting plate on the wall.
Anonymous
  • 8909 Answers
  • Posted on Mar 21, 2011
SOURCE: We have a Hotpoint RVM1435WJ01
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Samsung microwave ME21K7010DS displays C-10 when I select potato. Stats working but after about 2 min message C-10 appears. Works fine in other settings. Microwave is about 14 months old
Older microwaves can develop any number of quirks.
Instead I suggest calculate the number of cooking time minutes needed and use that for your potato.
Be sure to fork a few holes into the skin of the potato so it doesn't "blow" and redecorate the inside of your micro.
I have a new hotpoint microwave and it completely shuts off after 3 minutes and in a minute or 3 later it turns back on
First if it is brand new it has a warranty---call Hotpoint customer service or even take it back where purchased for exchange or repair.
HOTPOINT COUNTERSAVER PLUS RVM 1435 DISPLAY READS F3
"F3" on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On RVM1435-series microwaves, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1435XX###) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Removing a microwave
You can download GE / Hotpoint owner's manuals and installation instructions here.
1helpful
Hotpoint Over the Range Microwave is LOUD
WE BLEW 2 OUTLETS IN KITCHEN & COULDNT FIND THE BREAKER THAT BLEW
remove cover of microwave, find and check the fuse
I have a hotpoint over the range microwave that I am trying to remove. This unit is about 20 years old. How do I remove it?
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
