Question about Whirlpool Dishwashers
WE JUST BOUGHT A NEW DISHWASHER DU1345XTVB HOOKED EVERYTHING UP CORRECTLY AND RAN A QUICK CYCLE THRU IT AND WHEN IT WAS DONE THERE WAS STILL WATER IN THE BOTTOM. THIS WAS TO REPLACE THE OLD DISHWASHER SO IT WAS ALREADY HOOKED UP THRU THE GARBAGE DISPOSAL. WE CHECKED THE HOSES NO KINKS...VERY FRUSTRATED! HELP!! TRISH W.
    Master:
  • 414 Answers
Make sure the garbage disposal is working, if it is not then it will not allow
the dishwasher to drain. Also make sure there is not blockage in the intake port on
the disposal where the hose connects itself. If you installed a new disposal, there
is a knockout that must be struck out inside the connection port.
If you have an "air gap" installed (next to the faucet which looks like
a small cup upside down, it may be gunked up, remove and clean, or replace it)
If the hose came inside the dishwasher did you install it on the proper port on the
dishwasher pump, many have two and one is blocked off. (it is unlikely but depending
on the amount of water and the type of subflooring under the machine, it could have
pumped out unnoticed and drained through a wiring hole).
Hope this is helpful
Posted on Mar 26, 2011
SOURCE:
I stopped my Kenmore dishwasher during a quick rinse cycle and now it won't work. I ran it thru a test cycle and everything is ok. Complete light keeps blinking. What can I do?
Try either unplugging it or turning off the circuit breaker for about 30 seconds, then turn it back on. I had a similar problem that worked after I did this...good luck.
Nov 22, 2017 | Kenmore Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Recently there's been a white coating on dishes. Has to be scrubbed off manually or soaked in a vinegar/water solution. I flushed out the rotating arms to be sure water flows thru & it does. Checked...
use any brand of dishwasher cleaner from a local store and run your dishwasher with it.I would also recommend that a calcium lime and scale remover be ran through your dishwasher to clean it out.
this may have to be done a couple of times.
Jan 16, 2011 | Kenmore Dishwashers
New Danby dishwasher - no water flowing into it
it sounds like the shut off valve has failed and not letting water into the unit, change the valve and it should work, even if it turns like it is working doesn't mean the washer isn't stuck keeping water from comming thru
May 26, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
My dishwasher won't drain
It is possible that it ran thru the entire cycle but was unable to drain teh waste water ( usually the result of a clogged filter screen in the bottom of your dishwasher).. I suggest you either hand bail the water out and look for the drain filter screen or check where the drain hose is hooked up under your sink and possibly into the side of a garbage disposal..That could be clogged up too... Hope that helps...
Aug 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
did you route the hose with a loop in it ...? is the water dirty or fresh? I can help
Aug 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
Dishwashers Logo
133 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
