Comfort-Aire BHD-501 Dehumidifier Logo
Anonymous Posted on Mar 26, 2011
It stopped working. One display reads "CH" and
Anonymous
Level 3:
  • Comfort-Aire Master 43,501 Answers
  • Posted on Mar 26, 2011
Anonymous
Comfort-Aire Master
Level 3:
Answers
43501
Questions
0
Helped
10837737
Points
101584
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
My dehumidifier will not turn on. The two digital displays just read CH 01 It is a model # LHD45ELT8
heatman101
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Not working and it reads ch and 01 ?\
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
3helpful
Display reads CH 01 and dehumidifier does not come on.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
1helpful
LHD45EL Dehumidifier won't run
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 1 year old.
Top Comfort-Aire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
