I have been recording my VHS tapes to DVD's and have had little trouble doing this. I finalized all the DVD's so that I could play these in any DVD player.
However, I have come across two VHS tapes that have no sound on either one of my VHS/DVD players. When I play the VHS tape on an older VHS/VCR player, the sounds work. I don't know why this problem occurs because other VHS tapes made during this time records well onto DVD's(both of these tapes were recorded in 1998.)
Please help.
thanks!
Linda
Try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
SOURCE: DVD RECORDER + VCR
this shows that your tape needs to be cleaned we have vhs cleaner a liwuid type and dry type just play this and it will clean your tape head. the tape is stock up inside due to dirty tape head. does this answers your problem?
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
SOURCE: VHS tape will not eject.
Hi and welcome to FixYa,
Initially, the top cover must be removed. Theis would allow you to:
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
SOURCE: FINALIZING DVD+R DUBBED FROM VHS TAPES
The manual gives you incorrect info.
To FINALIZE disk:
1. Press [HOME] button;
2. select [SETUP].
3. Scroll down to DVD ICON and SELECT
4. Select [FINALIZE]
Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
