My model is AEV05KB and recently I see water on the cooling pipes sometimes it drips and sometimes it forms snowlike formations and also if I put the cover on the snow completely coveres the parts inside...
It sounds like the unit is too small for the area being cooled. You should figure the square footage of the area and use this th figure what you need.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Using the square footage and the chart below, determine the
correct cooling capacity. Cooling capacity is measured in British thermal units
(BTUs) per hour.Area To Be Cooled (square feet) Capacity Needed (BTUs per hour)
100 up to 150 5,000
150 up to 250 6,000
250 up to 300 7,000
300 up to 350 8,000
350 up to 400 9,000
400 up to 450 10,000
450 up to 550 12,000
550 up to 700 14,000
700 up to 1,000 18,000
1,000 up to 1,200 21,000
1,200 up to 1,400 23,000
1,400 up to 1,500 24,000
1,500 up to 2,000 30,000
2,000 up to 2,500 34,000
Make any adjustments for the following circumstances:
If the room is heavily shaded, reduce capacity by 10
percent.
If the room is very sunny, increase capacity by 10 percent.
If more than two people regularly occupy the room, add 600
BTUs for each additional person.
If the unit is used in a kitchen, increase capacity by 4,000
BTUs.
Consider where you install the unit. If you are mounting an
air conditioner near the corner of a room, look for a unit that can send the
airflow in the right direction.
