HI there,
To fix Runtime error 332, you should understand the concept of
Runtime error 332 and identify the causes of it firstly. What is Runtime
error 332? This error usually occurs when a DLL file is missing, or not
registered on your computer. It is a really common problem for windows
users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can
re-register the registry list to fix Runtime error 332 issue. For
example, if you encounter Runtime error 332 at dll files, to re-register
the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile
Download Repair tools (
http://www.registryquick.net/page/RegistryQuick_setup.exe)
3. Re-start your computer
If you can not find the specific file on you computer, you should
download it from the Internet and locate it to the right place.
#2 To fix Runtime error 332, you also can try to run free registry
scan for your computer. In my opinion, it is the most important step for
you to
and avoid other runtime errors effectively. There are various registry
repair tools available on the Internet that scan, analyze, and fix your
computer. Besides fixing your Runtime error 332, these tools will remove
any registry errors, invalid shortcuts, duplicate files and repair DLL
files. Eventually, you computer will be free from system error messages
and sluggish performance. What you need to do is to fix Runtime error
332 as well as other registry errors to prevent your registry from total
corruption. If you continue to run this damaged system and don't fix
Run-time Error, this potential risk will bring you more troubles, Even
system crash.
is it error 1309 error reading from file?
