the tracks with letters are misty island put c and d together for corners (swap other side) then rickty bridge inbetween on one side and switch track on other. For numbers pretty much you can go by number (start with 1 and go left) I had to fidget a little but it worked
The brackets come in two pieces. One that rides in the track and one that bolts to the door. You need to undo the bolts holding the two parts together. Align the piece with the rollers back into the track and then bolt the two parts back together.
Look to see if you can see mounting holes for the glass you may have to reach in and wiggle the glass around if that does not work than the window regulator may need to be replaced
go to the nordic track website, you can download a blow up of the treadmill that shows how where everything goes, you can also download any manuals you may need in pdf.
well you have to slide the cars on to a track piece in the right direction then configure the pieces in any way you want and then the battery motors should send the car down the track
The only way you can get the tracks to play in order is to rename them before you put them on the player.
eg.
Album title - 01 - Track name
Album title - 02 - Track name
Album title - 03 - Track name
Album title - 10 - Track name
and so on
The albums will stay together, and the track number will put them in order within each album. Just remember to use 2 digit track numbers or they will sort 1, 10, 11, 12, 2,3,4,5,6,7,8,9
