Amana SXD524VW Side by Side Refrigerator Logo
Posted on Jun 04, 2017
We have a side by side Amana Refrigerator Freezer. It is model SXD22S2L. We started noticing that the things in the door of the freezer were not frozen solid. Like cans of frozen jucie were not frozen, just liquid. The meats, etc. are still frozen but some bags of frozen blueberries, biscuits, anything soft, is not freezing. It is also not making any ice. The water dispenser for drinking still has water coming out. The refrigerator seems to be fine. What do you suggest?
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Mar 11, 2007
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 18, 2008
SOURCE: Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
rpbuice
Ron Buice
  • 161 Answers
  • Posted on Jan 21, 2009
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Anonymous
  • 72 Answers
  • Posted on Jun 20, 2009
SOURCE: Our freezer is not cold, food is defrosting, ice
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Anonymous
  • 2559 Answers
  • Posted on Aug 05, 2009
SOURCE: Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Refrigerator on my side by side Amana not cooling
check to see if you have a the fan running in the freezer, if not replace fan. if fan is running do you frost on the back wall of freezer, if so defrost by opening door for 3 to 4 hrs. turn back on and if frost returns in 3 to 4 days call for service
My amana smd22tbw freezer is not freezer
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Refrigerator progressively got warmer even with temp at #7. Noticed freezer got very warm, everything melted (ice and all), then refrigerator part got warm. The refrigerator sounds like it's running,...
heatman101
Amana side by side fridge model sxd22s2l freezer/fridge not cold
they can get up to 305 degree F they can make brown spots on floor... yes they get very hot(is normal)
Amana bottom freezer not working on model abb2524deq
I replaced the solenoid and my ice machine starting working again.
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
