Polaroid TTM-2401 TV Logo
Posted on Mar 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv screen is too wide horizontally. I can't see but what's in the middle of the picture. Do I need to purchase a new tv or is this something that can be fixed?
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Mar 25, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
34474
Points
429
Go into video set up and take tv out of zoom mode
it sounds like you have it set to zoom a standard definition signal and that will make picture become bigger than the screen and cut picture off
hope that helps
My tv made a little noise and then the picture disappeared. The screen is black with a vertical line of picture approx 1/4 inch wide going up the middle of the screen. Is it fixable?
Generally this is not good news. Even in the event this TV is repaired, it will work very long. This TV has a horizontal problem. This is the most stressed area of any conventional TV. The Horizontal Output Transistor will need replace, the flyback transformer is bad, you have bad power supply with horizontal capacitors that are bad, and last, is a possible bad picture tube. This TV is not worth the effort or money to repair. Thanks for asking and show all hands of support!
I HAVE A 50" PLASMA SAMSUNG TV HAS A 2" WIDE
Something is wrong with your logic board, you've got the option of returning this TV if it's still under warranty or buying a new one.
2answers
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
No picture on my tv and it has a horizontal line mid screen
either your vertical driver or output circuit capacitor(s) defective, try this remove rear cover and with something insulated like a straw prod and poke around the circuit board,sometimes theres a cold solder joint, if picture starts to expand on screen its a solder joint
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
Small strip of video (about 3 in wide) in the middle of the scree
Just to be sure that I send you in the correct direction, does this strip look like a shrunken picture with no height? In other words is it a horizontal bar?
Thanks,
Dan
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
[email protected]
Nopicture
No vertical deflection. Vertical output IC, caps.
TV SCREEN PICTURE SMALLER
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
