Anonymous Posted on Mar 25, 2011
I have a LG47" tv
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Mar 25, 2011
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1128221
Points
12184
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
  • Steve Mar 25, 2011
    You don't have to use the olde analog RCA outputs & inputs.
    Use any type that is supported by BOTH the TV's audio output and the receiver / amplifier's input. (If there's an unused HDMI input on the receiver and an HDMI output on the TV, I'd recommend using those).
Hello- I have my denon receiver connected to my tv with 2 front speaker,2 surround and center channel along with the sub. The problem is that when i play a blue ray, all my speakers produce sound including...
I need to know the quality of the speakers on the TV. Try unplugging it from the speakers on the TV and plug it into the souround sound speakers only and see if it plays differently. Double check your sourround sound and makes sure you did not reverse a wire.
DCBdigital.com
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Have surround sound only when play dvd..
if you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
2answers
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
2helpful
2answers
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
1helpful
2answers
Sound Problems with HD TV
get the digital audio optical cable and connect the to the tv- got it working tonight
2answers
New
Try to connect TV AUDIO OUT to TV AUDIO IN or AUX IN on receiver, when you get sound from TV, select SURROUND mode on receiver.
 Grubhead
Grubhead
SmartAviator
SmartAviator
