Question about Hotpoint Aquarius WF220 Front Load Washer
Something has got between the drum and its container and it catches on the spin cycle making a nasty noise. Question 1 How can anything get in there. Question 2 how can one reach in to remove it even when the rubber seal is removed?
    Genius:
  • Hotpoint Master
  • 1,481 Answers
I would enter via the sump hole ....Remove the hose 1st then you may be able to grab it failing this remove heater element and you will see it to remove...Good luck
Posted on Mar 24, 2011
SOURCE:
Something catching on drum
is it noisy in the spin cycle?on the back wall of the drum it looks like a peace sign,this is where the spider gear and or rear bearing is,the gear can crack from overloading or using to much detergent,this could be what you're hearing as you move the drum,if it's something between the tub it will end up in the pump but most likely it's from the spider gear,i've seen this before,when it starts to pin fast gravity pins the broken part to the side but when you move the drum by hand you can hear it,use it and keep an eye on it,if your washer starts getting loud in the spin you'll know it's the spider gear,it would cost more to fix it than have it repaired so this means new washer time.
May 18, 2014 | Kenmore HE2 Plus Front Load Washer
Grinding noise when spinning
May be bearing worn, but may also be something caught between the tub and drum. When empty, spin the drum by hand and check to see if there is anything catching
Apr 25, 2012 | LG Washing Machines
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hot point WF451 Issue. I want change the door rubber between the door and drum. How do I do this? Also the machine is making a noise on fast spin as if there is something in the drum catching. I have...
Hi for changing the door seal check out the video section on www.selfix-uk.co.uk there are a few videos on the wf including bearing change which also covers the door seal as well. As far as the noise in your machine it could be almost any thing...if it's a scrapping noise it may be a bra wire caught between the drum and container, if its a tapping noise it may just be loose wires hitting on the cabinet or you may have a coin between the drum and container if it's a loud rattle, you could also have something in the pump housing...it's hard to diagnose noises without actually hearing them sorry
Jan 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Well when it spins it makes a noise but not the whole time the it stops and starts again only during spin cycle.
If you put it onto just the drain cycle does it still make the noise without the drum spinning,if so then you can expect to find something stuck in the pump.If it is only doing it on the spin cycle then something has found its way into the drum.
Check the pump end first.
Hope this helps.
Aug 20, 2010 | Washing Machines
Spin the drum by hand, it make metal noise
Remove the rear lower panel of washer,and remove the drum belt.
From the front of the washer, spin the drum by hand, and if it feels rough or is rumbling, could be the drum bearings are going.
If there is something caught, it will make a completely different kind of noise, more like a catching or rubbing noise.
If no noise,then could be the motor that is casing the noise.
Hope this helps.
Jan 23, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
Everything works great -until the spin cycle - loud noise
Have you checked to make sure all three shocks under the tub are ok?
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Would not dry clothes to original dryness. Now drum is making a whinging noise at the drum spin as though its catching on something every time it rotates. Also made a very loud clattering noise as it...
I had this same problem. The drum spins on two small wheel which with the help of the drum belt support the drum. The wheels or their brackets may be broken and need to be replaced. These are accessable by taking the back off the dryer. Best to take the old/broken ones in to insure you get the exact replacement.
May 01, 2008 | Washing Machines
Hotpoint Aquarius WF220 Front Load Washer Logo
139 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
