this works with the Samsung range quite well also but you must get the sequence correct - phone blue tooth active BEFORE you turn on the headset then press and hold the on button until the blue light stays solid blue.
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Look up on Jabra for your model number. google jabra with model number then a comma with manual after it. The manual was the exact match and directions were very clear.
Sorry I post the wrong link before, for plantronics manual it is:
http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
