Canon FS10 Flash Media Camcorder Logo
Posted on Mar 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The battery is not charging despite being pluggen in for several hours. Camera does not even power on when pulgged in. Does it need a new battery?
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
  • Posted on Mar 24, 2011
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270558
Points
3723
Check that your charger is actually outputing the rated voltage.
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
1helpful
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
My camera won't turn on even though it's fully charged
Is there no sign of any light from the camera when you turn it on? When was the last time you used that camera? If you have left the battery inside the camera for quite some time, then most probably, it got exhausted. Despite of being charged for hours, can you put back to the charger again and see if it gives a red battery charging indicator? If it gives a red light, then you may need to replace the battery pack.
Hope this helps. Thank you for using FixYa.
2answers
I have had my S9600 for 4 years, for most of that time, when i changed the batteries, all my settings remained the same. Now, when i change the batteries, every setting has returned to factory standard...
No internal battery. After the batteries are in the camera for 2 hours, there is enough charge in the camera to hold on to settings for 6 hours. If you take longer than that to install fresh batteries, the settings are lost. Here's what the manual says:
DATE/TIME
DATE/TIME
OKOK:At the time of purchase and after leaving the camera for a
long period with the batteries removed, settings such as the
date and time are cleared. Once the AC power adapter has
been connected or the batteries have been installed for 2
hours or more, the camera settings will be retained for
roughly 6 hours even if both sources of power are removed.
1helpful
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Sansa Clip Won't take a charge...
Are you sure the cable you are using provides both data and power to the device? Some cables are data only and will not charge the device despite appearing so.
Has it held a charge before? If this is a new device and has not yet ran down then charged fully again yet, then I would return it.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
