Your model sounds like the West Bend 59055 - Large Coffee Urn, 60 Cup.
The User Manual for your coffer urn can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Instruction for making coffee can be found on page 5. For 55 cups is would take 3 1/4 cups of coffee.
Use an electric perc or regular grind coffee; if you grind your own this should be a medium to coarse grind.
Do not use 'drip' or finely ground coffee as this could plug the drain holes in the basket and cause the urn to flood.
SOURCE: How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
SOURCE: how much coffee does it take to fill a 55 cup
1 scoop for every 2 cups. Then work from there.Good luck. Ron
SOURCE: I set the maker to provide me with a large cup of
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
