Question about ClearOne Communications Max Wireless (910158001) Audio Conference
Where is the hold button located on the phone?
    Scholar:
  • 146 Answers
It doesnt really have one. you will have to use the flash button to put call on "hold" or just mute call when needed.
flash will put first line on hold while a second caller is added
technically this is a one line phone and therefore no hold button was needed
Posted on Mar 24, 2011
6ya staff
SOURCE:
How do you do a factory reset on a SVP S580 smart phone?
Take your phone and hold the off button located at the top right, and at the same time hold the button at the bottom center of the phone, screen will go black, continue holding until an apple appears, be patient it will take a few seconds, once the apple comes into view you can let go of the buttons, and you will notice the phone restart, this is also a reset, give it a few seconds and you should be back in business....Hope this helps!
Oct 11, 2014 | Cell Phones
How do you program #'s in to the phone
There are 20 memory locations to store numbers in, they are numbered 01 - 20. Press and hold the memory button until Memory Store shows in the display. Dial the 2 digit memory location or use the arrow keys to choose the memory location. Press the select/channel button which will show Store Name in the display if the memory location is empty or will show edit and delete options if the memory location has an entry in it. If the memory location is empty, use the number keys to enter a name for the memory location. Press the select/channel button which will show Store Number in the display. Enter the phone number using the dial pad. Press the select/channel button to save the entry. Press the memory button to end.
Here is a link to download the manual in pdf format.
http://www.uniden.com/pdf/TRU348om_VA.pdf
Jan 23, 2011 | Uniden TRU348 Cordless Phone
How can i format my n5800
on soft formatting:
*#7370# should still reformat the 5800 in the same way it re formats any S60 2nd edition or later phones.
on hard formatting:
try this to your phone. turn off your phone. then follow these instructions.
press and hold the following 4 buttons till the phones restarts completely.
1. hold the green button used to accept calls.
2. hold the * keypad
3. hold the number 3 keypad.
4. hold the power button located at the top of the phone.
press and hold the buttons until the phones starts by itself. it will take some more time to start in this way and remove your memory card and do it.
Nov 04, 2010 | Nokia 5800 XpressMusic Smartphone
Need to format again my nokia 3200 phone. can i get the code for reformatting this kind of model? thnx
NOTE: all the phone memory will cleared and your phone will be as good as new.
Nov 04, 2010 | Nokia 3200
My phone is locked up and wont turn off. how do i turn it off to reset?
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Oct 05, 2010 | Apple iPhone 3G
Jailbroken iphone gets stuck on apple screen and somnetimes on very lew red battery screen
    Try the exit from DFU mode
  1. Step 1 Locate the "Power" button. This button will be at the top right of your iPhone, next to the sim card slot.
  2. Step 2 Locate the "Home" button. This button will be located at the bottom center of your iPhone.
  3. Step 3 Select and hold both the "Power" and the "Home" button.
  4. Step 4 Hold both buttons for five seconds and then release them.
  5. Step 5 The iPhone should automatically shut down and reboot into normal mode. If not, hold both buttons for another 5 seconds.
Dec 18, 2009 | Apple iPhone Smartphone
Forgot password
Use Soft Key Reset
REMOVE YOUR SIM CARD
Locate your soft keys on your phone, should be buttons above end and send.
Press and hold both soft keys.
Locate reset button on your phone should be on side and in center you may need to use your stylus to depress it.
Gently press the reset button while still holding the soft keys, release the reset button but continue to hold the soft keys.
In about 10 Seconds it should ask you to confirm the reset, once you do it will be set back to manufacturers settings.
Hope this helps
Sep 25, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
How do I switch on the nokia n76
try to hold down the stop/end button or button might be on top
Apr 11, 2008 | Nokia N76 Cellular Phone
Hold button drops calls GE 29488GE2
does this just happen with the one phone ?
if so, try swopping that phone with another of the same type and see if the problem transfers with the phone or remains at the original location, if it transfers, you have a faulty phone, if it remains, you have a fault in the switch associated with that port.
Jan 29, 2008 | GE 29488GE2 Corded Phone
Hold button doesn't work
If the hold button does not work, it's most likely a well used button that has gotten dirty. If you feel up to it (at your own risk) you can take the phone apart and clean both the circuit board contacts and the rubber keypad for the hold button using rubbing alcohol and a rag, q-tip or Cotton ball. This is not a permanent solution if you keep using that button a lot but it may last for years??
Jun 18, 2007 | IBM Corded Phone IBM412CID
ClearOne Communications Max Wireless (910158001) Audio Conference Logo
130 people viewed this question
Top ClearOne Communications Lands Phones Experts
Ekse
Marvin
Marvin
Are you a ClearOne Communications Lands Phone Expert? Answer questions, earn points and help others
