Nortel i2004 IP Phone Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have new phones, not sure how to do call pickup
Anonymous
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Mar 23, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
34742
Points
372
  • Feature 75 or
  • Feature 76 plus the extension you need to pickup.
How i can activate 40 for my telephon?
40? It's the pickup code for a Panasonic system and it's the universal pickup code for phones in your ring group. Make sure that you and all the other people are in the same group and 40 will work. As an alternative, you can use the directed call pickup code. (41+extension) or program the phones to ring differently. This assumes a TA series system.
How to replace serpintine belt on a 1988 chevy scottsdale pickup.
You need a wrench to make lever on the tensioner to remove the old belt, best if someone holds it while you remove the belt, make sure the belt label is on under the hood somewhere, or better yet, take a quick picture with your phone to make sure you put the new one back on the right way...
Hope this helps...
My nokia 5610 gets restarted. i cannot switch it on
There is a new firmware for Nokia 5610. Depending on your network. Yours might pickup the following version - V6.60, V7.12 and V8.30.
Try updating your phone's firmware by clicking to this link below:
http://europe.nokia.com/A4579163
Make sure you meet the system requirements before proceeding and backup some of your important contents.
If the phone still does not show any improvement/s, I suggest you to send the phone to the Nokia Care Centre near you.
New battery, new alternator, will not start 1983 Nissan pickup, 2.4 L
Check all of your fuses. Make sure that your engine is getting gas. Does the fuel pump kick on? Have you had it tested for codes?
1983 town car 289 sometimes it starts sometimes not no ignition. replaced ignition module ,throtel position sensor coil dist.cap,and rotor.Thanks
THERE IS A PICKUP COIL IN THE DISTRIBUTOR, IF YOU HAVEN'T CHECKED THAT, IT IS PROBABLY EASIER TO CHANGE THE DISTRIBUTOR THAN TRYING TO CHANGE JUST THE PICKUP COIL. MAKE SURE THE PICKUP COIL COMES IN THE NEW DISTRIBUTOR BEFORE YOU BUY. THE PICKUP COIL OFTEN CAUSES THE PROBLEM YOU ARE HAVING WITH YOUR CAR
Need to now firing order of a ford pickup f1 1995
Here is a website full of quality information on the fire order of all fords it does have your pickup, since you did not leave the size engine I cannot give a direct link I sure hope this does help you.
Click here for the website
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Cisco 7970 ip phone, can't pickup call
Make sure you have both phones in the same call pickup group. I have never used the group pickup button. The regular pickup button is what I use.
Just to be clear the procedure is..once phone A rings you hit the pickup button on any other phone that is in the same group as phone A. After you hit the pickup button the call will be drawn to the phone that you hit the pickup button on. Once the call is on that set hit the answer button to answer the call.
It only light up when i pickup the receiver
Just went through the service manual for your product & you have an LCD display unit, this won't go bad overnite this is definately a faulty product... You will have to return/replace the phone .. there is a service tag number at the flip side of your phone ... i am sure you will get the warrenty back with it.
Olympia OL2112 Single-Line Speakerphone:
· Corded Phone
· Single-Line Operation
· 6 Programmable Buttons
· 400 Name/Number Directory
· Digital Full-duplex Speakerphone
· Large 4'' x 2'' Backlit LCD Display.
· Modular Direct Connect Headset Jack
· Message Waiting Indicator
· Conference Calling
· Caller ID
· Mute
· Part #: OL2112
FAME !!
1helpful
How do I add a new number into my Avaya (model 1408) phone's pickup list?
use list usage ext xxxx to find the pickup you are in
use change pick xxxx to amend the pickup group.
A station can only be in 1 pickup group.
Im not getting any spark from one of side of my 2 cyclinder kawasaki ninja 500 EX. Its an 1987. I have replaced the plug wires and the pickup coils. I switched the coil packs and both work. Im just not...
To my knowledge, a 1987 Kawasaki EX500 uses a TCBI with digital advance to fire the ignition coils upon receipt of pulse from the trigger/pickup coils.
Since the pickup coils are new, and you have swapped the ignition coild, replace the high tension wires and checked/replace the spark plugs, the the only cmponent left is the CDI (electronic ignition system).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Nortel Computers & Internet Experts
MrFixitSTTL
MrTrekot
MrTrekot
Garatuss
Garatuss
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
