Hello Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently Press and release the ON•OFF key repeatedly until your component turns off. Wait 4 seconds between each key press. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next code is sent. The Brand Code Search begins with the first code in the chosen brand list for that component and cycles through all the codes for that brand. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON•OFF key blinks four times and turns off, all codes in the chosen brand lists have been searched. The
Insiginia is not liste with the remote contro you specify here. It is possibe to get the code for your TV by search method.
programming the remote to control.
Brand Code Search mode is exited.)
