Check for a blown fuse or tripped main circuit breaker. (Your fuse box.)
https://www.manualslib.com/manual/1022077/Jenn-Air-Cce3401.html?page=18#manual
http://producthelp.jennair.com/Troubleshooting_Guides
Click the appropriate icons to troubleshoot.
My CCE3401B Model Overview from PartSelect com
SOURCE: melted plastic help!!!!!!!
While the cook top is cool, use a razor blade scraper to remove most of the melted plastic. Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop, and then wipe off the excess.
SOURCE: I cracked the glass on
Try your local dealer. The tops can be expensive. I have seen them start at around $300.00. Check your warranty and maybe you can get it done under that. They would put like 5 years on those tops. May have to tell them that it broke when you where cooking, blame the product, not you.
SOURCE: My jenn air espressions gas cooktop has four burners. When
Remove the round burner plates and clean thoroughly in soap and water. Clean the burner ring where the burner plates rest with soap and water.
Let me know what you find.
SOURCE: We have a CCE3401 Jenn-Aire
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
SOURCE: I have a Jenn-Air CCE3401 Electric Cooktop I want
Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
My real time work with facebook Im making over $2000 a month operating low maintenance. I continued hearing distinctive people divulge to me how an lousy lot cash th
can make on line so I selected to research it. All topics considered, it become all legitimate and has without a doubt changed my life. For more statistics visit below siteHERE?www.101pays.com
