I have the Samsung 58 inch plasma, PS-58P91FD.
The tv remote
wont work correctly. It's stuck on STB. I've tried all the reset
options. however it just keeps flashing on the STB button on the
remote, with a msg saying, STB on the screen. I
have to change everything on the tv itself.
SOURCE: i have a samsung bn59-00599a remote for samsung
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
SOURCE: remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: the green timer light just keeps blinking and the
you need to replace the capacitors on the DM . Very easy repair. You can get the V21 V19 dm repair kit at the following link which has the replacement capacitors and step by step instructions on how to do the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
