Question about Kenmore Elite 45986 Front Load Washer
Our HE3T washers made a load thump the other day when it started the spin cycle. It continued with the spin although it seemed out of balance. I adjusted the clothes and it seemed better. The balance issue got worse and today we pulled white plastic pieces from between the bellow and tub. Is it the front outer tub? the drum seems to be very loose as well. Time for a new washer?
  • Kenmore Master
  • 2,699 Answers
YouTube - Kenmore front load bearing 18 months and kaput! ....time for a new washer,the spider gear is gone,usually from using to much detergent,i've found parts of it in the pump,you'll know when you put it in spin it bangs very loud
Posted on Mar 24, 2011
SOURCE:
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Very noisy when on spin. The machine seem to be balanced however the noise on spn is like a jet taking off. it gets louder as the spinning speed increases.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Washing Machines
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Out of balance condition
I had a Fridadaire model and had the same problem. It could be 3 things. 1- the weight came loose that balances the drum. 2- the bracket that is attached to the drum could have cracked. 3. the bearings to the drum have worn out. All of these problems involve taking the washer completely apart. This is big process, but if you have time and patience it worth it.
Is this model belt driven?
Jun 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
When washer is in spin cycle drum is out of balance.
REMOVE THE FRONT PANEL AND SEE IF ONE OF THE SPRINGS HAS BROKEN, COME OFF AND THE TENSION OF THE BELT OR THE TENSIONER PULLEY
Apr 09, 2009 | Frigidaire FWS933F Top Load Washer
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washer makes loud thumping after finished spin cycle
    I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
    Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    214 people viewed this question
    fordexpert
    Harvey Mahal
    Kristen Denison
    Kristen Denison
    Level 1 Expert
