Microwave Ovens Logo
Posted on Mar 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Kelly
Level 3:
  • Microwave Ovens Master 3,740 Answers
  • Posted on Mar 22, 2011
Kelly
Level 3:
Answers
3740
Questions
Helped
2163088
Points
12091
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
How do I switch my Panasonic NN-CD989S from Celcius to Fahrenheit?
talk with your local service agent and see if he can advise on what to do as he probably has met this problem in servicing units and has to change the setting
Viking Hood Microwave and Convection oven quit - does it have a fuse in the oven?
Yes they do.
If you had listed the model number, we would likely have been able to point you to the appropriate Sharp service manual.
(Viking microwaves are just rebranded Sharp models with enhanced cosmetics)
Change panasonic convection microwave from celcius to farenheit
If it is able to do that it will be explained in the owner manual.
Either call Panasonic customer service with that model number or Google the model with "manual" for the book.
Panasonic would be your best bet.
The timer works but nothing else does
Have you checked the door safety intelock switches? This is the number one reason for no heat when all else works.
If the tiny contacts are burned, they cannot tell the oven that the door is closed. Door not closed, the magnetron will not come on ... no heat. forget what you know about the door, the switches must function properly to tell the OVEN the door is closed. Check them with a contunity checker or a VOM, if you have one. You will have to remove the cover to find the switches.
Thank you for your interest in FixYa.com
Sears Canada bought Eatons Canada back in 2002. Eatons sold Viking products. I bought I Sears Viking over the range Viking microwave built in 2002. Nomeclature # 851.8250800 Model # 82508 Ser#...
This is a Sanyo microwave. the "851" number is the manufacturer number or "source" number. I can't tell you any more about that particular model.
I would remove the circuit board (control panel) and check for damaged/burnt copper print. Where the copper is burnt, you can solder on jumper wires to complete the circuit.
I have Whirlpool FT338 combi microwave/oven. It takes 4 minutes to boil half a pint of water.This is a replacement model, as we returned the first one thinking it was faulty. Not sure what to do now
Measure out 1/2 litre of water and place it in a pyrex or plastic container. Take a temperature measurement. Say 15degrees Celcius.
Place microwave on full power for 1minute.
The temperature rise of the water should be at least 10 degree Celcius. Say 25degrees Celcius.
If it is, the magnetron is producing aproximately 720Watts of power and acceptable, any higher and a bonus!
WHAT IS THE MAX TEMPERATURE THIS MODEL CAN SUSTAIN NN-CS599S LET SAY I WANT HEAT THE SUBSTANCE FOR 300 CELCIUS FOR 10 MINUTES..HOWEVER THE OWEN REACH THE SET TEMP AT FIRST 5 MINUTES....IS IT THE OVEN CONT...
I do not know of ANY microwave that will get you anywhere near 300 celcius, the cavity thermals are rated around 110.F and even the mag limit thermal of the comercial units are 300F No where near the celcius temps you are talkig about.
HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
1helpful
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
