The compressor could be gone, the niose you hear will be the internal fan unit running , this circulates the cold air arount the inside of the unit. If this unit has a timer, it will be a located in the compressor housing well in the lower rear of the , it will be separate from the compressor and will have 5 wires plugged into it, on that unit, locate a small round knob and turn it clockwise, it should start, if it does, replace the timer, if not, check the thermostat. This may need a tech to do safely as you are working with a live curcuit.
Hope that helps but without being there it quite hard to explain.
Dont forget to vote and goodluck, need more help contact me [email protected] and if you are in Perth Australia, I can have a look at it.
Testimonial: "Thank you! that was perfect. I disconnected power, moved timer knob clockwise(only way possible) and it worked! Great! I'l buy new timer. BEST ADVISE!"
Hi,electrolux american style fridge freezer was ok but has started to stop freezing noticed this last week ,did a bit of investigating found the cooling element frozen up ,defrosted it worked ok for seven days did it again this weekend ,defrosted it again works ok ,looks like defrosted thermostat ,but why is it lasting 7 days
