Question about Airlink AWLH3025 Wireless Adapter
Airlink AWLL3025 usb wifi will not work with Windows 7.Is there a way to fix this?
  • 5,968 Answers
The drivers are only available through XP, http://www.airlinkplus.com/driver/wireless_download.htm .
It might be possible to use the compatibility mode to force the driver to load. To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
However, in the case of a wifi adapter, this doesn't help since you will not be able to share the wifi with the virtual computer. You would be better off finding a different brand of wifi adapter that is win7 compatible. See microsoft.com for the hardware compatibility as you look for models: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
I hope this helps.
Posted on Mar 21, 2011
SOURCE:
I cannot install airlink wn710np wifi usb adapter because windows cannot find the needed software on the web
Check the box that the adapter came in because if it doesn't automatically work then it should come with software.
May 11, 2011 | Computers & Internet
Wireless connectivity is it possible on the EL1352G
Greetings - Looking at the specs of the machine at the E-Machines website it doesn't appear to have any internal slots for a WiFi card upgrade.
However, there are plenty of USB ports available and an inexpensive USB WiFi dongle ($15-20 USD) would work just fine. Doesn't matter which one, as long as it has drivers for Windows 7 (which would be any recent USB WiFi hardware).
Regards and thanks for using Fix Ya.
Mikeywaf
May 04, 2011 | eMachines EL1352G-01w (884483537679) PC...
I cant find the driver download for the airlink awll3026 i got windows 7 now, and cannot get internet...
Download from this link here. According to their technical announcements the windows XP driver works on Vista and 7. There are 2 variations of the driver but not enough information from your question for me to determine which so download this one first and try it. Although they affirm their driver will work in Vista and 7 I would only install the driver and not the whole software suite. Windows does a fine job managing the wireless connection anyway.
Apr 06, 2011 | Airlink AWLL3026 (AWLL3028) 802.11g/b...
How can I install AWLL3025/NA USB wireless on windows 7
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 19, 2011 | Airlink AWLH3025 Wireless Adapter
Airlink adapter and att router access problems
Make sure you have the most up to date drivers for both your mini usb adapter and your router.
The 64 bit version of windows 7 may not have the right driver for your equipment.
Will get better with time.
Good luck.
Jul 04, 2010 | Airlink (AWLC3025) Wireless Adapter
I need a driver for Airlink AWLH4030 working with windows 7. The original driver starts error mesages about wlanapi.dll Thanks Rafi
had the same problem(awlh4030). The chipset on the adapter is mfg by Atheros.
If you use the Atheros ar5005gs wireless network adapter driver that comes with windows 7 it works with no problem.
Dec 20, 2009 | Airlink AWLH4030 (658729080430) 802.11g/b...
Lost drivers cd
You can download your driver here just input any necessary data.
http://www.lge.com/support/software.jsp
hope this help.
Jan 24, 2008 | Airlink AWLL3025 802.11g/b Wireless...
Airlink AWLH3025 Wireless Adapter Logo
1,517 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Shawn DuRee
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
