The simple and honest answer is probably not. This remote has very few codes and will only work with a small number of devices.
As the code listed for DirecTV receivers didn't work, you could try the codes for other brands of satellite receivers. There are only ten of them (00 to 09) so it wouldn't take long! DirecTV receivers have been made by several different manufacturers in the past - Pace, Thomson, LG (Zenith) - but they still use codes listed for DirecTV rather than codes listed for the original manufacturer. Code 08 for Zenith (LG) may be worth a shot on the off-chance that your receiver was made by LG and will respond to this code. It's highly unlikely though.
If none of the Satellite receiver codes work, then the remote wont work with your receiver. It's not really a universal remote and it does not have a code search or learning feature and cannot be updated with additional codes. Hitachi simply included a small number of codes for the most common devices in use at the time your TV was on sale. Devices manufactured later are unlikely to be controllable with this remote.
If you want to have one remote to control your TV and DirecTV receiver, you would probably have more success programming the DirecTV remote to operate your TV. The other alternative would be to buy a universal remote that will work with both. If you would like assistance with this, please let me know the model number of your DirecTV receiver and/or remote control. You can reply to me by clicking on "Add a Comment" below your question.
Hope this helps - probably not the answer you were hoping for though.
Regards,
BElectric
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control.
[^] For future reference,write down each working device
code
OK.
Yes It works now. Code 09 worked
Thank you very much.
