I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on then turns to a black screen again. The longest it stays on is when I first turn it on, after that it only last about less than a min.
Re: I turn my tv on the picture and sound all work and...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
My tv is doing the same thing, on about 30mins then goes black. I still have sound. I turn it off then immediately turn back on and lasts about 5 mins. Have you ever found out what the fix is?
My tv is doing the same thing, on about 30mins then goes black. I still have sound. I turn it off then immediately turn back on and lasts about 5 mins. Have you ever found out what the fix is?My tv is doing the same thing, on about 30mins then goes black. I still have sound. I turn it off then immediately turn back on and lasts about 5 mins. Have you ever found out what the fix is?
You can't post conmments that contain an email address.
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG.
No display in monitor
Jan 11, 2013 Ps3 and hdmi cable
Oct 8, 2012 More results from ccm.net
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
? 5:56
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
have usb barcode scanner I need to plug into keyboard port
Ac not cooling, no leaks
