Hello Yogesh...
Unless you are familiar with the BASICS of REFRIGERATION...
H3" ERROR CODE means it is "
Out of ORDER"...
Broken: Needs repair.
By searching the internet "split A/C " It defines a
COMPRESSOR overload protection is trying to
SAVE your equipment FROM SELF DESTRUCTION.
See
second detail sheet (below)
COMPRESSER"
Is the heart of MOST modern refrigeration systems.
In a SPLIT system it is the outside unit with the FAN
that should be running when the COMPRESSER is
in action. Typically then compressed &
COOLED
REFRIGERANT is then piped into a cooling element
EXACTLY LIKE MOST REFRIGERATORS where the
cooling takes place (expansion valve and evaporator).
Treated AIR (indoor) is then blown through the
evaporator... cooling the room and warming the
refrigerant (which continues to cycle back to the
outside unit where the compressing cycle
continues until the INSIDE temperature is
achieved... (thermostat on the wall)
COMBINED"
pretty much means EVERYTHING but those combined refrigeration units seen
WORLD-WIDE HANGING OUT OF WINDOWS... or on roof-tops with DUCTING for
treated AIR" to be pumped where needed.
Similarly
heat pumps simply have reversible valves...
which turn the coils around (functionally).
There too are
split-system (inside/outside) & combined units.
Excellent refrigeration
primer (below)
https://camec.com/cameccatalogue/documents/000948_IbisTechManual1.pdf
Alarm Codes
Gree Air Conditioners Error Codes
Hope this helps.
Carnac the Magnificent
Fan on dometic air con not working
