My neff 5543 fitted dishwasher has stuck on drain. The pump will not stop running, even if I open the door, or re-set the programme. The only way to stop the pump is to turn the whole thing off. Any ideas what's wrong? Is it easy to fix? Thanks in advance Neil in MK My Hotpoint Aquarius DWF33 dishwasher appears to be stuck on drain with the pump continuously running. Nothing will budge it from this apart from switching the whole thing off. Any ideas?
This is a on going problem with asko and they keep jerking everyone around with this defect. I had a repair person come over and used a turkey baster with a 7" rubber hose attached to the end of the baster. He took off the kick plate and inserted the hose end in the overflow tray and pull about of 12 onces of water from the tray. He is a asko repair facility and says it is a comon problem and has made the repair solution on his own as it is easier then taking the hole dishwaser out and tip it on the side just to drain the water. This has been on going for 3 years and each time i called asko it was like i was the only person having such a problem. I now do this every 3 months and the problem is on going. What a piece of junk. Purchased at Marcellas appliances in Schenectady,NY. They also know how to avoid the problem in fact there repair person left out most of the screws so the next time it would take less time to drain the water. DDDDDont buy ASKO. Michael Foote
