Mr. Coffee Iced Tea Maker TM1S Logo
Posted on Mar 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had a Mr. Coffee Ice Tea Maker Given to me with no information on how to use it ? model# tm36p sn tm30p
Lance Hill
Level 3:
Genius:
  • Master 1,739 Answers
  • Posted on Mar 21, 2011
Lance Hill
Master
Level 3:
Genius:
Answers
1739
Questions
Helped
800629
Points
4235
Unsure of which model number you are looking for a manual. Currently available manuals for Mr. Coffee Ice Tea Makers are available here:
http://www.mrcoffee.com/InstructionManuals.aspx
One of these should be close enough to your design to be of some assistance.
Shuts off before done
Is the second one I bought they both do the same .... thing I stand there and hold the button in to get my ice tea made are they going to recall this or what's the problem
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
How do i get a manual that i can print out
I am looking for a manual on an Ice Tea Maker - Mr. Coffee Model 3.5
2helpful
3answers
Where can I get Mr Coffee Tea Maker manual online
kitchen.manualsonline.com/manuals/mfg/mr_coffee/mr_coffee_ice_tea_maker_product_list.html - C
1helpful
2answers
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
1helpful
My dad gave me his Mr. Coffee Ice Tea Maker, but I have no instructions on how to use it. Can you please help?
Specifics may have changed for newer models -- we've had ours and used it happily for many years -- but the basics are simple.
(1) Fill the pitcher with water up to the "water" line and pour that water into the top of the appliance.
(2) Fill the pitcher with ice up to the "ice" line.
(3) Place a coffee filter and a family-sized tea bag into the top of the brew/steep basket and put the cover on that basket.
(4) Put the brew/steep basket on top of the pitcher.
(5) Slide the pitcher next to the appliance, such that the hot water exit port on the side of the appliance lines up with the entry port on the brew/steep basket.
(6) Press the "on" switch on the front of the appliance and wait for the tea to brew.
(7) When the brewing/steeping process is over, the appliance turns itself off.  Replace the brew/steep basket with the pitcher lid for pouring and storage.  Discard the tea bag and coffee filter, and rinse the brew/steep basket.
(8) Enjoy your tea!
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
