SOURCE: GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
SOURCE: no water entering
age of unit? type of use ie: heavy - 3 loads a day, or light - 3 loads a week. that will clue us to likely culprit.
breaker tripping suggests excessive amperage. if you have 120 v at the solenoid valve then the valve is bad. you also might have a clogged line. if you turned the water off in the house for something, and the plumbing is older galvanized, there is often 'sanding' of fixtures that causes problems with toilets most often, but anything with a filter. that could clog the valve, but not very likely.
the timer is a board. do not have schematics, but usually easy to locate because the wiring eminates from there to the pump, the inlet valve, and the door soap disp. look for arc markings where you can see. a mirror will help.
the element could have overheated and tripped the breaker but that would not stop if from filling.
i suspect its the power supply to the timer region that is likely the cause. check the obvious / easy first. then test the voltage on the sol valve.
the manual may be downloadable from ge. not sure.
good luck
mark
SOURCE: GE Nautilus Dishwasher soap door
Click here to view the diagram. Hopefully it will help answer your question.
SOURCE: GE Nautilus Dishwasher model info
the part is about 124.00 and for the labor, who knows? Sorry I don't know
SOURCE: GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
