Nokia 6300 Cellular Phone Logo
Posted on Mar 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia6300 froze whilst i was texting i decided to switch it off..now it wont switch back on the two blue lights at the side of the phone come on though...ive check the battery and thats okay.?
Anonymous
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Mar 20, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
55
Questions
0
Helped
8032
Points
195
Thats software problem , your 4ne need to be flashed.
My friend texted my Nokia Lumia 900 and the screen froze. I tried unlocking it and turning the screen off and on but it still won't work.
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 01, 2012 • Cell Phones
1helpful
Froze blue screen
software fault take to a mobile shop to reflash
2helpful
2answers
Late receiver
HI
I don't think so, because there are lot of factors why your phone receives late text messages, one is coverage of the service provider and outage. try using sim card on a different phone and then check if its doing the same thing. one factor is if your phone can't pickup that good signal then chances are message will come in late, try texting your own mobile number using the 11 digit dialing patern or put 1 before your number.
hope this helps
25helpful
5answers
Phone went off only blue light showing
well plug the charger into the phone with the battery still intact.....then remove the battery while the phone is still plugged in. then unplug the charger and plug it back in........place battery back into phone and then power it up. That worked for me.
Feb 01, 2009 • HTC G1
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
2answers
6300
Try removing the sim and memory cards then try to switch it on, whilst the charger is plugged in. If it still fails then it does need to go away for repair.
Blue screen, phone won't shut off!
Basically there is a software issue with your phone. The operating system has become corrupt or the proccessor has taken a dump. If it is under warranty you should get it replaced.
Phone switching off wont switch back on
samsung jet has just turned itself of now it wont turn on again
Jun 13, 2008 • Cell Phones
Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
1helpful
4answers
Froze blue screen
Interesting - did it get wet or did you try to flash it..............the phone is in flash mode and you will have to flash the phone with the proper software package to recover it.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
