Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
I'm having the same problem... my ws-55511 was working fine then it shut off. I've tried turning it on several times to no avail. When I unplug the tv and let it sit for 3 minutes, it still will not power up. I tired holding the menu button and Device button on the set together for 5 seconds to see if a two digit error code will blink, but nothing does.... the little green light flashes a few times, but nothing on the screen. Any assistance would be greatly appreciated.....
hello, i found this string while searching for same problem. holding the two buttons i get 10ea twin blinks.
does anyone have any suggestions?
I have the same problem. The two digit flashing code after holding the menu/input button is 1,2
Jay
Same problem with my 5 year old WS-55511. The power light will come on for 3 seconds then go off. I have tried holding the device and menu buttons, but I do not get any code at all. I read else where that there was a possibility that the capacitors on the DM Module could be bad and may need to be replaced - I did that, but did not have any success. I don't mind replacing components on a board, but I wonder if I should just look for a new TV? Any other suggestions?
I have the same problem and when I hold the 2 buttons I get a 1 and then 2 what does this mean
