SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
SOURCE: can't set the clock on a 1987 Quasar Superwave
I had a similar problem--no manual--but found this way to set the clock:
1) Be sure colon is flashing (unplug and replug)
2) Press the 10 HOUR/MIN, 1 MIN, 10 SEC/MIN, and 1 SEC/MIN buttons until the correct time displays.
3) Press the CLOCK button.
Hope this helps.
SOURCE: I need to know the wattage on my old 1990's model
You probably already know, but the wattage is 800. There should be a sticker or plate on the back or underneath the unit with some specs.You can also try calling Sanyo Fisher service for more info at 800-421-5013
Monday - Friday, 7:30AM - 5:00PM PST
Also check http://kitchen.manualsonline.com for a manual.
I really hope they can help you.
SOURCE: The unit at times would make a grinding type of
exhaust fan on convection oven making loud noise
