Technics SL-BD20D Turntable Logo
Posted on Mar 20, 2011
I need stylus for sl-bd20 .what model ? and where online ?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Mar 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
1794
Points
22
The stylus you need depends on your cartridge brand. Wich one do you have? (It will appears printed on your current cartbridge).
SL-BD20 arm drags across record on return
Hello Jim, for what you say, the arm of your tray returns before you finish reading the disc?
If so, it may be that the return system of the arm is stuck or missing cleaning or lubrication, if you have the knowledge, should review the operation of said system, suggestion, remove the lower cover of the tray and aopye the tray in four high legs, which allow you to see the operation of the mechanism and see if it is working free or stuck
If not, go to a specialized technical service
Greetings Franco Dosil
Hola Jim, por lo que expresa, el brazo de su bandeja retorna antes de que termine de leer el disco?
Si es asi, puede ser que se encuentre trabado o falto de limpieza o lubricacion el sistema de retorno del brazo, si tiene los conocimientos, deberia revisar el funcionamiento de dicho sistema, sugerencia, retire la tapa inferior de la bandeja y aopye la bandeja en cuatro patas altas, que le permitan ver el funcionamiento del mecanismo y ver si esta trabajando libre o atascado
si no, concurra a un servicio tecnico especializado
Saludos Franco Dosil
https://www.manualslib.com/products/Technics-Sl-Bd20-Service-2611757.html
1helpful
2answers
Not sure which stylus fits my sl-2500 cartridge
The proper stylus is the best you can afford. However the cartridge itself will only take certain types. To find which simply enter the cartridge make and model number into Google and see what comes up.
Actually most hi-fi buffs say it's the cartridge and stylus combined that gives the best sound, since many cartridges fit only one stylus it's often the cartridge that is the real choice. Most turntables will take a wide range of cartridges, so you pay your money and take your pick.
Need a needle for a TECHNIC SL-3350
It's 'TechnicS' and 'stylus'. Wouldn't a web search have been faster?
"TECHNIC SL-3350 stylus"
But even 'technic" and 'needle' would have worked.
http://www.lptunes.com/Technics-SL-3350-turntable-stylus-replacement-p/tstsl3350.htm
2helpful
2answers
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
2answers
Hi. I'm have a problem with my Technics SL-BD20 turn table I've just purchased. When putting the arm onto the LP it just skips over the surface to the middle. Why does it do that? Cheers.
Try adjusting the tone arm weight so that the arm will be slightly heavier.
If this does not help, see if the tone arm manual lift handle is operational and fully released when the arm sits on the record.
Another possible cause are the tone arm position sensors inside the unit.
Hope you can fix it.
regards
Triarcuate
Turntable turns, but there's no sound.
Well, the motor itself is completely separate from the sound. The path of the sound is basically
Styli -> Cartridge -> Tonearm -> RCA Cables -> Input Source
I would say start from the beginning. Check your stylus. If it's ok, then that means your Cartridge is probably ok. Make sure you have a secure connection from the tonearm to the cartridge assembly.
There really isn't much else to it.
If you cannot get it to work, I would suggest taking it to a service center for assistance.
- OPTiC
Electronic Repairs & Service
A DJ Pro Audio Co.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
