Is there any fuel? Running a fuel injected vehicle out of gas is not good for the fuel pump as the gas is what is used to lubricate and cool the pump. If fuel pressure ok? Try banging on the tank with your fist while someone cranks the engine. If it starts or trys to start, suspect a bad fuel pump
One way to check the fuel pump is to turn the ignition to on and listen for the pump to run. It should run for a few seconds. It may be a couple of seconds after you turn the ignition to on before it runs. Normally you can do this repeated times.
If you don't hear the pump run that is most probably the problem.
Is it possible that there was a body ground wire that didn't get hooked up , or got bolted to a spot on the new fender that was covered with paint causing no ground ? Just a thought.
check fuel pump turn the key on and listen for a buzzing sound coming from the fuel tank if not then your fuel pump is done. try hitting the bottom of the tank and seeing if that helps to get it to a garage to fix it.
Unfortunately the fuel pump can still be bad. The pump has a check valve on it that wears out. The pump will continue to run but, struggles to supply enough fuel to start the engine. You can buy a fuel pressure test gauge from Auto Zone or that type of auto parts store and check the pressure. You can purchase a fuel pump from them too.
check your timming .dist may have moved on you this happend to me i have a 2500 gmc pu.ran fine .started,my truck it ran moved about 20 feet and dyed .cranked over but no start just by fluke moved dist back and a way we go try that .good luck ED.
