Pinnacle HD Mini Stick  TV Input Logo
Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After downloading channels, the picture shows up on the preview small screen. Any way to expand to full size picture on laptop
Anonymous
Level 3:
  • Master 449 Answers
  • Posted on Mar 19, 2011
Anonymous
Master
Level 3:
Answers
449
Questions
Helped
137811
Points
1193
Usually Alt-enter or ctrl-enter expands to full screen.
My down load picture are so small, how do i enlarge them, so i can post them
Ok, you see when you download images from google or other service; don't download from the results page! in google; click the image, then click 'view image'; image opens in new window; right click on it and save the full image.
down-load-picture-small-enlarge-post-3x24vpx20nhydej15kwplfm4-5-2.png In Bing; just click the image; the full preview fills up the screen, save.
HOT TIP: to get better resolution images:
1. Google: click search tools; under size: select large
down-load-picture-small-enlarge-post-3x24vpx20nhydej15kwplfm4-5-5.png 2. Bing: click Image size, select large.
down-load-picture-small-enlarge-post-3x24vpx20nhydej15kwplfm4-5-9.png Good luck! Vote if you found this helpful
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Tv picture is in corner of screen, about a quarter of the screen size. How to restore full size image.
Sounds like you have picture in picture capability and you are seeing the pip preview screen as your main screen. You'll need to switch to the other screen and possibly select a different input.
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
7helpful
2answers
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
2helpful
I have changed the screen size to 16 x 9. There is black space at the top and bottom of the screen. What do I do to correct this?
Hi welcome to Fixya,
Presently there are 16 formats (sizes) transmitted and you may need to hit a button to show a full screen sometimes on some channels. The format , aspect or size buttons are on both the TV remote and any cable / dish remote you have . set the TV to full or 16x9 if using a cable / dish box, then set the box to the stretch mode and the picture should be full, there may also be a zoom setting that will fill the picture but may cut off the edges.
Respond with more details or try the suggested settings
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2answers
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
JUST PURCHASED A 60 INCH DLP TELEVISION MOST TV CHANNELS ARE NOT FULL SCREEN.... WHAT STEPS DO I TAKE TO INLARGE THE PICTURE TO FIT THE 60 INCH SCREEN ?
Channels that transmit in 480 or 720 may not fill the screen. You can use the Aspect or Zoom button or feature to expand those channels to fill the screen but there may be some stretching in one direction or parts of the picture may extend beyond the edge of the TV. Some TVs have a "justified" setting that will not distort the center of the picture and just stretches the corners. Look in your manual for Picture Size, Aspect, or Zoom for details about your TV.
1helpful
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Top Pinnacle Televison & Video Experts
ExpressFiX
ExpressFiX
Vinho Xie
Vinho Xie
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
