Question about Kenmore 24032\24036 Top Load Washer
I have a 10 years old Kenmore Elite washer. After the 1st washing process stops, I have to push the cover with my hands so it could continue the rest of the process. What should I do?
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
Based on the info in your post, it sounds like a common top load washer problem. Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...but it includes your model)
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck. Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Posted on Mar 19, 2011
SOURCE:
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
The washer quits half way thru the cycle and we have to push the stop button, wait a few seconds and push start again, it starts and then stops once again and we to repeat this process. Afterward, it...
How old is your washer? There is a problem with certain models that require an upgrade. Here is a number to call 1-800-659-7026. Give them your model number and serial number off of the machine. This problem is with the control board.
Dec 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Lights on Front Panel Flashing
Another posibility is the door lock switch is broken. When you open the door, on the middle right hand side there should be a small pin sticking out from the washer that the door pushes on.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stops suddenly and water isn't drained out
Hi tieuvodanh; Sounds like the timer has gone out. If you can advance the selector dial manualy, and the machine continues to operate as it should, then this is the problem. Replacing the timer will require some advanced knowledge of washers and the ability to use a box of hand tools. A good handy man will be able to repair this for you. Best regards; HELP2DIY Please don't forget to rate my answer.
Jul 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
426 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
