Question about Sony Bravia KDL-26L5000 26 in. LCD HDTV
When on button is pressed on the tv remote tv may or may not turn on, but it can be turned on manually with on/off button. Even tried a new remote, with no luck. Any idea? Thanks.
  • 11,361 Answers
It may have bad IR receiver board located on the front of the TV, or worst case will be the main board that is not processing the signals from the IR receiver properly, so far I cannot locate the repalcement IR receiver for your TV yet. You may have do more searching for replacement parts. More indepth troubleshooting needed.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Posted on Mar 19, 2011
  • 1,591 Answers
When you changed remotes, did you use the same batteries? The batteries in the remote may just be almost dead.
Clean the Plexiglas in front of the infrared receiver on the TV.
SOURCE:
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Looking for a working remote code for a Magnavox/DVD TV combo (model MWC1305). Auto search not successful.
I'm not showing that we have a code for the Magnavox/DVD combo. I have provided the power scan instructions. Please let me know if you have already performed these steps. Thanks.
This is to program your DISH remote to your TV:PowerScan1.Turn the TV on2.Press and hold the TV POWER button for three seconds - The LED shouldflash3.Press the TV POWER button 4. Press the UP orDOWN arrow buttons on the remote (about one press per second). Stopas soon as the device turns off. -The TV should turn off5.Press # - Now addressed
Dec 27, 2011 | Big Button TV Universal Remote
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
How can I program an RCA remote to an APEX tv?
Is your TV older than the remote's programming date by at least 6 months? The code you need for a newer TV may not be included in the remote.
If the TV is compatible with the remote codes, then try the Apex codes: 1037, 1043, 1050, 1071 . You can also try the manual coding. Turn on the TV (turn off other devices that may respond to the IR signal). Then press and hold the TV button on the remote (the illuminated TV will turn on). While holding the TV button, press and hold the On/Off button. The illuminated TV will turn off. Continue to hold both buttons for at least three seconds, until all of the component names light up. Then release both buttons (the TV will remain illuminated). Press the On/Off key repeatedly (up to 200 times) until the TV turns off. Press Stop to save the code. Try to use the remote to control another function on the TV. Repeat the manual search if the code doesn't control the TV completely.
If the TV light blinks 4 times and goes off, you have searched through all of the codes. The remote exits the manual search at that point.
I hope this helps.
Nov 21, 2010 | RCA RCR660 Remote Control
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
I need instructions for the zenith universal remote 3201 for a new Panasonic LCD TV
If you have a manual for remote and you try all codes for your model and it didn't work, you may try for automatic search. First turn on TV, and point the remote toward the TV. You press: SETUP and hold, and press button for device: TV, lite is on, then you release all button and press again SETUP, just once, the lite is blinking, now press the power button on a few seconds. When your tv is turned off, you press button TV. Press button for power and it will turn on your tv. Try other commands on your remote, if everything is working that's it, if not do procedure again. Hope this was helpful, if not, ask more. By!!!
Nov 03, 2009 | Zenith ZN-501S Remote Control
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
Cant get the remote to turn tv on off or channels
hmmm.. Do you have another remote that will operate that tv, try that remote and see if it will turn on and off the tv. IF you bought this new remote because your old one quit working it may be the tv and not the remote. If you have a camera phone you can check your old remote. Turn on your camera and aim the remote at your phone, look at the picture on the phone and press the power button on the remote, you shuld see the front of the remote flash, if you do then it is the tv causing your issue.
Sep 02, 2009 | Philips Magnavox 20MT133S 20" TV
Programming our dish network remote control. We do not have the remote code for our new Coby MODEL: TF-TV2214
1. Turn on your TV. 2.Press & hold the TV Mode button until all Mode buttons        light up. 3.Press red power button 4.Press the UP ARROW repeatedly (about 1 press per second) until your TV turns off. 5.Press # POUND The TV Mode button will flash three        times. 6. Press the POWER button to turn the TV on and try other buttons to make sure the code works. If you want to try another code, start over from step 1.
Below is the website for the online manual which will give further instructions.
http://dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/6_3_RemoteManual.pdf
In looking at the manual no codes are given for the Coby brand TV. If the above process does not work, you'll have to call DishNetwork for further assistance. It may be that the remote will not work for your TV.
Dec 06, 2008 | Televison & Video
How do i program my remote
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
Aug 25, 2008 | RCA DISH Network(r) 311 Satellite System
Sony Bravia KDL-26L5000 26 in. LCD HDTV Logo
331 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
