HP OfficeJet 7410 All-In-One InkJet Printer Logo
Posted on Aug 02, 2008
Problem Powering Up
My machine is on, but, the only thing showing on the screen is the HP symbol and a line that keeps going back and forth which makes me think it is warming up. This happened before and the machine eventually powered up on its on.
(It's been warming up for 5 days.)
  • 1 more comment
  • carl_brown Aug 07, 2008
  • horrigaj Aug 12, 2008
    Same thing.....right after a power surge during a thunder storm.
  • Anonymous Aug 14, 2008
    I'm having the same problem, power went out today, cannot turn HP on or off, unplugging does not help!!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
96
Points
Hi Carl. Solution is to unplug the wireless card from the back of the machine. You are all too good!
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Hp dv6000 2 beeps when powering on...
Usally when laptop beps when it comes on it could 3 differnt things 1.ram is to much 2.hard drive failed
3.or you have a programming promblem.
1helpful
Washer does not work!
NF = No Flow (water).
1.Is the water turned on? 2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
14helpful
3answers
Carriage jam message
I had this same problem and spend hours working on it. Took the side panels apart to get a better look. Nothing anyone said fixed the issue. Not even the link everyone keeps posting to HP's carriage jam fix. Was out of solutions and about to give up and order a new printer. There was one last thing I had to try that I didn't think was going to work, but I had a theory. Right after I tested this solution it started working again. This worked for me, but anyone who has tried every and have not got their printer to work can try it.
My Solution: Open the front covers and look inside. Just above the metal rail that the carriage travels on there is a thin plastic strip about 1/4 in. width and should have a glossy shine to it. I believe this is some kind of positioner. It runs through the carriage and gives it some kind of position. After years of use, it'll become dirty with ink. I used some tissue and alcohol and wiped the strip clean. It worked perfectly fine right after. Below is a picture of the strip I underlined with a yellow line.
k24674
Grand Canyon Tech
Grand Canyon Tech
