SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
SOURCE: Maytag ice maker
I have maytag msd2756deq the water in icemaker is not comming. I replaced the dual water valve too.
Mani
SOURCE: dead and wont move cant charge but batties are ok
sounds like a dead battery on the unit. see if you can get it replace .
SOURCE: '07 5403 John Deere Tractor lift arm will not lower
some-times the 3pt linkage can go past the top position.
When this happens - you will need to force! the linkage arms down.
SOURCE: My Pride (Ameriglide) Backpacker Plus Lift Stops
If it's stopping in the same spot, it is a limit switch that isn't making contact with the lift sensor.
Here's a link to the wiring diagram that shows where the limit switches are.
ftp://webfiles.pridemobility.com/pdf_files/ipbs/domestic_us/silverstar/us_backpacker_plus_ipb.pdf
If it is tripping the circuit breaker, either your are trying to lift too heavy a weight, or the motor is pulling too much amperage due to previous abuse, or misuse. These are good lifts, and if you bought it new, then get ahold of your dealer and Pride will fix the problem. If you bought it used, they may have been using it to haul concrete...who knows?
