Washing Machines Logo
Posted on Aug 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fabric conditioner dispencer not working
Fabric conditioner wont dispence. Have cleaned the dispencer & around the inside of drawer space.
How-2-Repair.com
Level 3:
  • Washing Mach... Master 746 Answers
  • Posted on Jul 30, 2013
How-2-Repair.com
Level 3:
Answers
746
Questions
0
Helped
592055
Points
1880
Fabric conditioner wont dispence This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
Level 1:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 24 Answers
  • Posted on Aug 02, 2008
Anonymous
Contributor
Level 1:
Teacher:
Answers
24
Questions
Helped
29788
Points
50
Dispenser trays have a narrow hole at the base of the unit.. this is most likely blocked with gunge... pour bleach into outlet and push a straw through to clear obstruction. Once cleared take drawer out of machine regulary and wash in hot soapy water to prevent a repeat buildup.
2answers
Bosch classixx 1200 fabric softener dispencer doesn't empty into machine just fills with water
Pull out dispenser drawer in the middle section for fabric softener lift up top plastic cover and flush out hole with water and this should solve the problem
1helpful
My kenmore he2 wont dispence the soap in the soap dispencer
Evening to you
Allow the washer to start a cycle and have the dispenser drawer ajar and observe through which dispenser the water goes.
Does the first stream go through the pre-wash dispencer,secondly notice where the main stream goes and lastly where the softener would go. If this can help you in any way just put use the dispencers as fits the washing.
goodluck
Kolbrun
The detergent dispencer is full of water at end of machine cycle. also I cannot seem to be able to remove the dispencer drawer for cleaning.
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Softner in detergent drawer dispence at the wrong time
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
14helpful
Fabric softener dispenser does not empty on Bosch Classic washing machine
I have a bosh washing machine and the fabric dispencer was not emptying, i took the compartment out and washed it all out making sure all the muck was off. Then i looked in the machine (where the dispencer had been) and looked up. There were some holes so i got a needle and poked it up and wiggled it, some black muck came out, i cleaned the rest of the holes and now it is working again.
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
1helpful
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
1helpful
Fabric softener dispencer
The inlet for the softener may be plugged. Try a toothbrush to clean the area.
Bleach and Fabric softener not dispencing
One thing that I did was to clean out the filters on the inlet hoses.  This increased the water pressure to the machine and improved the situation.  I am still having trouble with the bleach dispenser.
Top Washing Machines Experts
john h
