SOURCE: My epson 3490 photo scanner isn't working theres a
If the start button light is flashing red, it is because of one of the following problems:
After trying these solutions, unplug the scanner to turn it off, then plug it back in.
SOURCE: I have lost the power cable for my Epson perfection 3490 -
Hi Dave!
Go to a good elecronic store and buy a power cord.
Juste be sure that you have the info about the cord you lost.
You will find that info here:
http://files.support.epson.com/pdf/pr349p/pr349ppg.pdf
Just make sure that the voltage and the amphere is correct.
Any good elecrtonic store have replacement cords stored.
Good luck to you
Nic
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
SOURCE: My Epson perfection 3490 photo scanner doesn't
I googled Epson support and found the answer. Here it is:
Macintosh Leopard Support
Contact Support
Welcome to Macintosh OS X 10.5 Leopard support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Macintosh OS X 10.5.
Check your Epson product CD to see if it already contains Macintosh OS X 10.5 drivers. If the CD indicates support for Macintosh OS X 10.5, follow the instructions that came with your Epson product to install your drivers and other software.
If your CD does not list OS X 10.5 Leopard, follow the Step-by-Step Instructions below.
View our Macintosh OS X 10.5 Leopard FAQs.
