Casio DR-210TM Calculator Logo
Posted on Mar 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the tax % rate on a Casio DR-210TM?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1442
Points
1 ppm = ? scfm ( air )
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 135 Answers
  • Posted on Mar 18, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
135
Questions
0
Helped
24482
Points
398
Youll find your answer right here in the manual:
http://www.retrevo.com/support/Casio-DR-210TM-Calculators-manual/id/12440bh226/t/2/
800kb pdf file.
Hope this helps. Good luck!
kc
13helpful
How do I change the tax rate on my Casio dr-210hd from 5% to 6%?
Press AC twice Hold down % set key for 4 seconds. Input tax rate (6%). Press Tax+ key, then press % set key
Source: http://www.casionz.co.nz/Site/CASIO/files//settingandusingtaxandexchangekeys.pdf
How do I clear a paper jam for a Casio DR-210 TM calculator?
Just pull it out, take a pair of tweezers and pull, there is no easy way to do if you can't make it feed out.
2helpful
Need to change the tax rate from 7.75 to 8.75 onmy Casio DR2220HD
I found my manual papers.
Push the CA button
Hold down the set key (%) until the 0 prints and shows on the screen.
Then type in the new tax amount and hit Tax+ .
You will also need to repeat the above for the Tax- .
This works for my DR-220HD Casio Calculator.
Good Luck
22helpful
NEW casio DR210TM not sure how to set tax rate
To change tax rate on Casio DR-210TM:
Hit <CA>
Hold <%> for 5 sec until '0' re-appear
Enter 'Tax Rate' and <TAX+>
4helpful
Changing the % tax setting on calculator
First hit "CA" Key. Then hold down the "%" key for 3 seconds. Then input the tax rate. Next hit the
"TAX +" . Then hit the "%" again. You are done. make sure the printer is on.
Tax rate reset
refer to dr-250hd calculator
10helpful
2answers
Casio DR-250HD calculator
make sure you are in "print mode" step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input tax rate step 5 press the % button now check to make sure that is correct.
36helpful
Casio calculator
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
