Linksys WRT160N Wireless Router  Logo
Posted on Mar 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help setting up the Sudenlink Modem to Linksys Router
Computer hardware and networking support
Level 3:
  • Master 4,281 Answers
  • Posted on Mar 18, 2011
Master
Level 3:
Answers
4281
Questions
0
Helped
972257
Points
12566
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
I would like to reinstall the router linksys 2,4 GHZ 802.1.1g Please write me the steps one by one (now i had a router netgear,but it is to weak, the former linksys has had more power) Thaks for help Peter...
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
3answers
I tried to set up my wrtg54 linksys with my new motorola modem from at&t. The linksys says it cannot find an internet connection. Of course, when ethernet is taken out of comp to plug into router, the...
Good day,
The AT&T modem(Motorola), is actually a modem and a single port router.
To work with the Linksys it must be set up in bridge mode. Then let the router make the decisions.
AT&T tech support will usually not help you if the router is not there product.
On Google, there are many sites that will help with this issue.
Unless you've already done it, you should contact AT&T by phone and request tech support on setting up your modem. They will talk you thru the whole setup, including testing but without the router.
Then proceed with the steps thru Google.
I do not know the settings for your specific router, but the forums will usually help.
I assume you're on DSL. Make sure they know that. Cable settings are different.
How can I setup my Linksys 54g v2.2, with my ZyXel 660r modem from embarq so that I can use my laptop with the routers wifi?
First of all you need to set you modem router to bridge mode. go to this link will explaine in more detail
http://kb.earthlink.net/case.asp?articale=69205
remember to change the linksys router ip to 192.168.2.1 or 192.168.0.1 somthing different from the modem .
Hughes modems are all set to 192.168.0.1 so simply setting the linksys router to default 192.168.1.1
you need to change the linksys router IP to somthing different 192.168.0.1
1helpful
2answers
I currently have a cable modem that the Linksys router has been working with for the last couple of years. Yesterday it started acting up by not letting me go to some sites. Today, it has failed...
1helpful
2answers
I have a Linksys WRT54G router. The power went out the other day and I haven't been able to establish a connection since. I can connect when I run cable from the modem to the cpu, but not if I try using...
what is the model of your modem? if you said that you are able to get online when your computer is hooked up to the modem only, then it indicatest that your modem is not yet in bridge mode. Putting it in bridge mode will make your modem a "pass through" device thereby causing no conflicts in asking for ip add/connecting to your ISP. when your modem is in bridge mode, you should not be able to get online.
after setting your modem to bridge mode, connect your linksys router. if you have a pppoe connection, or one that uses username and password, have that set up in your linksys router. at this point, your router will be the one to ask ip adds from your ISP.
you could also visit this site, http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=PH/Layout&cid=1166859677881&pagename=Linksys/Common/VisitorWrapper&lid=7788193882H13, for further configuration of your router. as for your modem, try to call your ISP on how to set your modem to bridge.
2helpful
2answers
Linksys wirless G 2.4 broad band router download driver
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
