JVC AV-32S575 32" TV Logo
anthony arcillo Posted on Mar 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know the service mode of JVC TV flat screen
Basuki Jrobenk
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • JVC Expert 177 Answers
  • Posted on Mar 18, 2011
Basuki Jrobenk
JVC Expert
Level 2:
Mentor:
Answers
177
Questions
0
Helped
69445
Points
522
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
JVC TV model,s avk14t3-1 has sound and no picture in audio-video mode
it needs service, that means using tools and meters and spare parts to find cause.
dead screen black screened at all times.?
even in HD TV antenna mode for HD TV?
or just the remote CLICKER batteries dead.
tell things that work and no not work , even LED actions.
the maker has no books on this old TV
https://jvcproducts.com/us/contact/support.html
here they are ask them>?
what rare TV. good luck fixing any RARE TV.
moved you to TELEVISION.
I have a 37" JVC flat screen,.,.model # LT-37xm48,.,. i am unable to pick up channel 11,.,. which is a prime station in our area,.,.,. could this be fom being a "vhs" as to a "uhf"
Do a reset to this tV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
I have a JVC-LT19DK8ZJ flat screen TV. The DTV menu has stopped working - the screen goes black when I try to click through which means I can't retune it. Do you know how to reset it?
Whats wrong with my tv?
This indicates that the TV somehow went into service mode, and the colors on your screen are a test pattern. There are a couple things that we can try to fix the issue.
The first, is to try and reset the EPROM in the TV.
To do this, remove the power cord from the wall, then press and hold the power button on the TV itself (not the remote) for 20 seconds. Then plug the set back in and power it up.
If this does not fix the issue, the last thing we can try on a user level, is to use the TV remote, and press Cursor Arrows UP then Down, and unplug power. Then plug it back in.
If this does not cure the issue, then this indicates a failure in the TV's EPROM which is what runs this Test/Service Mode, and there are no resets or adjustments you can perform to fix this. It is actually a fault in the component that generates this test, and the set would require service. There is nothing you can do that would enter the Service/Test Mode as a user, so this likely occurred due to hardware failure.
If your TV is still under warranty you can contact JVC from their service page for repairs below.
I hope this helps!
- Joe
JVC Official Service Providers site Purchase genuine JVC parts and...
Jvc flat screen wont turn back on when cc button was pressed too many times , ??? Hotel Tv.
Try a hard reset. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Locate reset button on a JVC TV #LT32DV20 Flat screen
There is no external reset button to modern TVs. You have to enter its service mode; to reset it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How do I exit "audio only" mode when "press any button" per the screen instructions does not exit the audio only mode? Press any button does nothing.
Contact the authorized service centre for JVC. It sounds line corrupted firmware. Let them do it right. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
Access service menu on jvc LT-42P300
JVC LT-52P789 no picture just sound
If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
How to trouble shoot problem with JVC Slim TV with blue color on lower leftcorner and green on the upper right color? Also, the display using VideoInputs are not correct horizontal.. the Screen is tilted....
http://www.go-gddq.com/upload/2009_03/09032313026620.pdf
www.scribd.com/doc/.../Sanyo-TV-LCD-Training-Manual
www.scribd.com/.../JVC-LCD-FLAT-Television-LT26WX84-Service-Manual
www.scribd.com/.../282-29-JVC-HD-ILA-Basic-Model-Training-2007
These service and training manuals above show you how to troubleshoot and isolate any problem, and what to do about it, please have a look and download and use all the information, in the manuals and you will soon isolate your issue.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
