SOURCE: Casio MTG-2638
good after noon1maybe your watch is need of alinement,but as long as your watch is working good that`s no problem.thanks ! god bless !....
SOURCE: Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
SOURCE: Casio SPF70 Spring Pins
The best way is to take a look on ebay. The only downside is: you have to buy a whole lot (I mean - you can not buy just a two or three springpins). Go to ebay, choose jewellery and watches and then watch parts and tools or accesories.
The other way is to try to find on internet jewellery and watch part supplyers in your coutry and contact them. They usually selling springpins in packs of 10.
Before you buy any of them, you need to measure the distance between watch case lugs in milimeters. The size between lugs is the exact size for the springpins to order.
If you are not happy with that, then you have to try to continue to visit more jewellers till you find the right ones.
Don't forget to rate, please.
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
