http://taperssection.com/index.php?topic=139638.360
"Hi all,
maybe I can offer an explanation why some people have the RTC problem and others have not. After leaving my M10 on the shelf for about two months without switching it on (batteries were still fully charged!), I had to set the clock.
So I wondered what is going on. I pulled out the schematic of the M10s big brother, the D50.
The power supply section is rather complicated with lots of MOSFET switches and regulators, even one for the RTC battery. Checking the component values, I guesstimate that it takes about 30 to 40 hours to recharge an empty RTC battery - the state of the battery is in when you are asked to set time and date. If fully charged, you can expect 2000-3000 hours of RTC operation.
It seems to me that the D50 (and probably the M10) switch off completely when battery powered - not even the RTC battery is recharged!
So it depends on your use profile whether you have the dreaded "set date and time" problem or not. Regular use (best every day) keeps the RTC battery charged. in the future, I will let it go into sleep mode, and not switch it off. Another solution is to plug in the power supply before storage and let the M10 run for two days to top off the RTC battery, this should be sufficient for two months.
BTW if someone could send me a schematic of the M10, I could replace my educated guess with fact.
Greetings,
Rainer"
