Powerware 3105 500i (0790341043681) UPS System Logo
Anonymous Posted on Mar 17, 2011
Good afternoon The system has a red light flashing constantly and is emitting 3 beeps every thirty seconds. Thanks for your help.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
8662
Points
38
The battery in your UPS needs to be replaced. You can contact the manufacturer for a replacement battery -- depending on your warranty, they may replace it for free.
http://powerware.eaton.com/Products-services/Backup-Power-UPS/3105.aspx?cx=3
Testimonial: "Thank you very much - I suspected as much but found the troubleshooting area of the manual a little difficult to decipher !"
  • Anonymous Mar 17, 2011
    No problem -- glad to help!
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
1helpful
My ps seems to have crashed!! it will only turn on momentarily,the light goes blue for a second, flashes orange?? then turns off!! the red light flashes till i touch the power on sensor,beeps then goes...
Hi tomtoremar,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
1helpful
When i turn on my ps3 to choose a user it doesnt show any of the users i have, so obvioulsy i cant do anything on my ps3. All it shows is the wavy background, Help me pleaseeee!
Try doing a master reset of your system.
1.) Turn off the hard switch on the back of your system and wait 30 seconds.
2.) Turn the hard switch back on so that the PS3 displays the red "stand by" light on the front LED.
3.) Hold your finger on the soft "on switch" (above the red LED) for about 10 seconds until the PS3 emits a beep.
Good Luck!
-Tom
8helpful
5answers
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
15helpful
4answers
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
1helpful
2answers
Display doesn't turn on, emits short beeps and blinks lights
Sounds like a low power problem, Check the power supply with a good ohm meter set to DC voltage if voltage is less than 14 v. Replace the supply. DWW
Top Powerware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
