Normally, laying a refrigerator down will cause any debris or sediment to float through the tubing and eventually end up in the filter drier which contains silica beads to absorb moisture. Debris will then plug up the drier. A technician will be required to evacuate the sealed system. He will then cut out the old drier and braze in a new drier and recharge the system.
There is usually no guarantee that this will fix it because if the debris is large, it may clog a capillary tube and render the unit un-repairable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
SOURCE: A church member donated a freezer to our church, I
You pluged it back in after you laid it doun. You needed to let it stand back up to let the freon to get to the condencer. You can try to unplug it for 2 days now to see if the freon will go back down or you might need to have it serviced now.
Good Luck
SOURCE: layed down freezer to transport in car for long
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
