Ask HP yet? be wise no?
we are not HP.
https://h30434.www3.hp.com/
no PC stated, my guess not HP puter.!!!
NO OS stated. (not all OS caN RUN IT)
only THIS
5187-7583
this is a reclic PS2 keyboard, Ill quote HP:"
HP Multi-Media keyboard 5187-7583 uses a PS/2 connector, and is over a decade old.
do not move PS2 devices from one maker to other. ever.
they are not standardizes like USB are.
see?
https://h30434.www3.hp.com/t5/Desktop-Hardware-and-Upgrade-Questions/computer-windows-10-not-recognize-keyboard-5187-7583/m-p/6007467/highlight/true#M141768
WE STOPPED USING ps2 DEVICE IN THE LAST CENTURY
Why are you using this? now, in 2017
did you know, (can prove it) that some PCs cant even send enough power to many PS2 devices,
that is because it is NOT THERE device.
solved, buy USB devices.
and end any usage of XP now. for ever.
and win.
SOURCE: My keyboard DVD keys are not working
If you want to check the drivers just type Device Manager in the start box. Once in Device Manager find your keyboard and click on the "+" sign, then right-click on your keyboard model. You should see update driver, also one of the tabs will tell if it is working properly and if not there is a Troubleshooting box. Also try going into the Control Panel and clicking on your keyboard/mouse. There are settings there alsol
SOURCE: Buttons, some not working, HP Enhanced Multimedia PS2 keyboard
look for the model numberon the bottom of the keyboard and google search it with the word "drivers"
SOURCE: the sleep button on the ketboard does not work
you will need the driver for the keyboard you can find it at Hp's web site under your computer's model under support and drivers
SOURCE: Keyboard drivers for audio shortcut buttons
Download on Driverguide.com
user Username: driver2
Paswword: all
SOURCE: multimedia buttons(stop, start) etc not functioning
if you use winamp go to preferences - global hotkeys and check the 2nd box (enabled) i had this problem aswell but after i checked the preferences and did what i just told you it works fine now ^^ and if you are using mediaplayer try to search for the hotkey options (i am pretty sure that mp has 1 aswell)
Click on the "Start" button in the lower left
corner of your computer screen to open the Start menu so you can change the
mouse sensitivity. Locate the control panel link on the right-hand column of
the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the
"Search Control Panel" bar at the top of the menu on the the
right-hand side. Type in "mouse" (no quote marks) in the window and
locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings"
at the bottom of the mouse menu and click on the link. When the mouse
properties window appears, locate the tabs at the top of the window and find
the one that says "Pointer Options."
Click on the "Pointer Options" window tab and
locate the heading that says "Motion." In the Motion section, find
the slide ajustment bar that is labeled "Slow" on the left side and
"Fast" on the right side of the bar.
Move the bar according to your desired speed and
preferences, and click on the "Apply" button on the lower right-hand
side of the window.
Click the "OK" button on the lower left-hand side
of the window, which will take you back to the default window. Verify that the
mouse sensitivity is according to your needs and readjust if necessary by
repeating these steps.
Good luck
do rate the solution if got help
