Question about Timex Indiglo Analog Watch
How to replace stem and crown in timex indiglo watch?
    Sergeant:
  • 302 Answers
If you have the stem and crown take it to a watchmaker. If not it is cheaper to buy a new watch
Posted on Mar 16, 2011
    New Friend:
How to replace the stem on my watch
Posted on Oct 08, 2012
SOURCE:
How to remove stem on timex indiglo WR 30M ?
Insane as it seems, apparently the Indiglo wr30m watch stem does NOT have either a set screw or a release button. No vice needed though, just good fingernails. Pull it out one click to the 'set time' position and pull it out some more and it comes out.
Mar 06, 2011 | Timex 27191 Wristwatch
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
I have a men's Timex Indiglo watch with day and day of month. It has only i stem. How can I set the date correctly? Lois
Your question brought a smile to my face as I had one also and had the same problem. It took me hours to finally figure out that the stem pulls out to set one thing and pulls out just a little more to set the next.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Mar 10, 2010 | Timex Indiglo Watch
I have a timex indiglo, mens watch, A christmas gift, and am having problems setting the day and date. The stem appears to have only one setting, notch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMES watch manuals. Rate me, please
Mar 09, 2010 | Timex Indiglo Watch
Timex Expedition Compass watch stops randomly.
Some watches have crowns that screw in after being pushed home, is this the case with yours? If it is then that could cause the problem described. (Turn crown clockwise).
I looked at one or two of the Expedition instructions (the are a lot) but couldn't find any mention of a screw in crown.
I suggest that you go to Timex.com and at the bottom of the page is "manuals/downloads" select this and the "product manuals". Put your watch type in the search box to obtain your manual.
If you are still not able to solve the problem, the I suggest you take it back to a Timex dealer to sort it out.
Jan 28, 2010 | Watches
Setting day and date on timex watch
For the analog Timex Indiglo with both day and date (CR 2016 Cell on back) and only the single crown available you must first pull out the stem and turn through the hours 24 at a time to get to the correct day(MON,TUES,etc.). Then you can pull the stem out only half way and set the date (1,2,3,etc.). Be careful to attend to the AM/PM time as you turn the stem for the day. Go too far and the day will change at noon and you have to wind through seven more 24 hours to correct it.
Nov 26, 2008 | Timex 27191 Wristwatch
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Timex Indiglo Analog Watch Logo
2,254 people viewed this question
Top Timex Watches Experts
freddyfox
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
